Ok, so spanky has been down for a couple of weeks because it was not getting spark. Checked using a known good module, still nothing. So, I figured I would just replace the whole disty. Well, upon removing the old one, I found a wire stuck to the side of it in a small black square that was attached with a screw. This wire goes to the + side of the coil. Well, not knowing what that little black square was, I assumed it was some kind of distribution block for that wire. Since it was the only wire going into it, and I couldn't get the screw out to remove it, I just cut it off and put a new end on it. This end I connected to the same hole the black box was screwed into. Well, as soon as I turned the key, no power! My girlfriend was standing right in front of it, and all she can tell me is "there was a little smoke around here (as she points to the whole drivers side of the engine bay!)" The main fuse blew, but I am thinking that wire I grounded out caused the problem. What exactly is this wire and black square for? It looked like a ground but was going to the + side of the coil. Can I just remove this wire completely? It isn't in the harness or anything. Just a single wire from the coil to the disty housing. Thanks
One thing after another!
So, I took that wire completely off, replaced the fuse, and it fired right up. It ran for about 1 min. and started jerking and missing and then just died. It won't start back up yet again! What is wrong with this thing?! FWIW: Fuse is still good.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
is your 89 carbed ? sound light the black box on the distributor is bad the connect to the coil i think its called a ballast anyways if not that then u have the fins back word do wut i do number 1 piston up number one on distributor use a sock to turn the crank and align with number 1 piston has to be up make sure u check crank white line at 0 dtc this is an easy check i just did mine the same wayFORD BUILT TOUGH SINCE 1987-1993 FORD FESTIVA LX
Originally posted by 1988redfordfestiva View Postis your 89 carbed ? sound light the black box on the distributor is bad the connect to the coil i think its called a ballast anyways if not that then u have the fins back word do wut i do number 1 piston up number one on distributor use a sock to turn the crank and align with number 1 piston has to be up make sure u check crank white line at 0 dtc this is an easy check i just did mine the same wayOriginally posted by 1988redfordfestiva View Postanother ? gas wut kind u using
i use 89 in mine and 93 once in a blue moonThe normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
WOW !!! 6 post in less than 20 min someone should learn how to use the edit button.Last edited by Maxtiva; 02-26-2010, 06:11 PM.
Originally posted by Maxtiva View PostWOW !!! 6 post in less than 20 min you should learn how to use the edit button
Originally posted by 1988redfordfestiva View Postdo yourself a favor pull plugs check the compressionOriginally posted by 1988redfordfestiva View Posthow long ago did u do a tune upOriginally posted by 1988redfordfestiva View Postcheck your wires with a ohm meter on ohma and check your wires to the plugs check oil and coolantOriginally posted by 1988redfordfestiva View Posti'll try and help u as much as i can i hope u dont have it back wards the distributor can go either way but make sure u know the firing orderi think its i1342 but i'll check and give u a link
http://autorepair.about.com/library/...-firing-88.htmOriginally posted by 1988redfordfestiva View Postyeah with out the black box you'll fry the disty i had this same issue i had to get mine from a mazda with it on it longer wire then connects to the coilOriginally posted by 1988redfordfestiva View Postya u need that black box best way to get the screw off umm alittle heat and tap the screw with a screw driver and a hammerOriginally posted by 1988redfordfestiva View Postsorry guys was tryin to get him info but yeah he needs the black box on the disty that connects to the coilKidding.
Doyler, did you cut the wire in such a way that you can just splice it temporarily and see if that fixes the problem? I recall Ogrestiva having a similar problem after having not reconnected that wire a while back. Not sure what exactly it does.
P.S. If you do throw it into the FS section, I'd be up for a road trip to IN.:p
1989 L - 247K miles Slick
