Still new to this car and this forum, but my son called me to tell me that he thinks he blew the head gasket. Had recently driven the car and it was running just fine. he got home and decided that it was a good idea to check the oil level as his rear main seal is leaking and he didn't want it to runn too low. Car was running fine as I stated, no idication of over temp or engine running hot, no shudder, no sputter no white smoke to speak of. Pulled the dip stick and he had the "vanilla shake latte" on the end.
I checked under the oil fill cap and there was some condensation but said it has always been that way. Checked the radiator but there was still coolant visable in the radiator, but it was low but not down to the cooling fins yet.
Wondering what the next thing I need to do? I have been planning on doing an engine swap with a 94 Aspire engine we picked up that had very low milage. Just need to determine on the best route to go on removal of the engine and what I am going to need to pull from the old engine. His 88' is carburated while the Aspire was FI. There is a port on the aspire for the mechanical fuel pump, just verified that. Just need to know if I can pull the engine out the top of the engine bay without having to pull the tranny with it. I just replaced the left CV shaft and do not wish to go through that with both of the axles.
Can the engine be pulled without the tranny? anything I should be watching for that might make the removal more difficult? I am open to any suggestions that will help me get this car back on the road, its my sons transport to school. Thanks again
