There's a plug in my dash that I'm not sure about. It actually plugs into a dead panel beside the rear defrost switch in the dash. It's the one to the right.
In love with a MadScientist!:thumbright: There's a fine line between breathtaking ingenuity and "That's the stupidest thing I've ever seen!"
those are nice if you do any extra power electrical device add-ons to the car... you can then just tap into the hot line in those connectors.
-Aspire brake swap COMPLETE! https://www.wunderground.com/persona...?ID=KOKOWASS38
ok so if there is a plug in the dash is there a plug in the hatch? can someone snap a pic of the plug if so? mine has some un plugged plugs in the hatch but the car isnt here right now for me to take pics and check.. thinking of adding the rear wiper myself
Reason: italics
the one in the rear is under the hatch panel... basic 2 plug connector (one is 90 degrees to the other)
don't know if all hatches were wired for it though??? maybe one of the non-wiper guys can check.
I'll check. It seems strange that a wiper system wouldn't have plugs at all appropriate ends...
i think you are right, i dont see a T connector in my hatch. only a single wire connector (blue with green) and a 2 wire connector side by side, blue and blue with orange
Having that extra power would be nice for something. I may route it to the rear of the car to be used as an auxiliary power jack for friends' phone chargers & stuff. I've even contemplated a power splitter through the clock delete on the dash so that I don't have wires running all over when I use my GPS and cell phone charger.
Now that's an idea!
Post a thread with lots of pictures if you do that, please
Now that's an idea!
I'll do it asap, even if I don't actually make it happen. Won't be too hard. I figure with such low draw as chargers pull, the tiny wiring that they used in the harness won't be taxed too much.
