I was driving the other day and all the suden i had no dash lights. I figured I blew a fuse but I couldnt find any that was blown. Is there just one place that there are fuses? or is there some other reason I dont have dash lights? Thanks!
No dash lights?????
I dont know. I dont have a radio hooked up and there was some bare wires hangin and I remember one sparked. then thats when I lost the lights. but I just thought those wires was radio wires....I blacked taped them up now but still dont have lights1990 festiva*green paint with stylin black 14's
*God Bless you all*
Did you check the Tail Fuse(15 amp), I think that is the one that goes to the cluster not the Room Fuse.Originally posted by black beauty View PostI figured I blew a fuse but I couldnt find any that was blown. Is there just one place that there are fuses? or is there some other reason I dont have dash lights? Thanks!'90 LX
yeah, it just pops out and its got those tab things holding it in. If your worried about breaking something just take your speaker out and depress the tabs from behind. Like I said if its the problem the back of it will smell burnt.
Nope didnt check that one. but im going to now! I thought it was the room fuse. thats the only one that made sense to me. but thanks!!Originally posted by wybnrml View PostDid you check the Tail Fuse(15 amp), I think that is the one that goes to the cluster not the Room Fuse.
ok, Ill check that if that tail fuse isnt the problem. Thanks!Originally posted by big_ty2003 View Postyeah, it just pops out and its got those tab things holding it in. If your worried about breaking something just take your speaker out and depress the tabs from behind. Like I said if its the problem the back of it will smell burnt.1990 festiva*green paint with stylin black 14's
*God Bless you all*
Let me know what you come up with for the answer because I am having the exact same problem. My cluster lights and shifter lights (automatic) do not work at all, but the glowing tail lights do come on when the headlights are turned on. Here are several things that I have tried so far with no luck ( maybe it will work for you):
1) Light Dimmer Switch
2) Park relay
