Other than a bat tstat?
History
90 fi 5spd
Just put in a used short block with 135k miles with some blow by. All other stuff came off of orignal engine. Which ran at a normal temp. before replacing short block.
Rebuild head.
Have set timing by feel and gas milage. Best gas milage is 41, normal is 38. Maybe running rich?
Cooling fan has never come on. Temp guage needle sits on hash mark of normal range. Heater is only ok, not hot.
Can't tell if engine power is good or low. Car does not have any reserve power in fifth gear at 60/65 mph. Don't know if this is normal or not.
Idles at 2000 rpm give or take at first start up on cool mornings till starts to warm up. Is this normal?
Changed from auto to 5 spd trans at same time.
Has Aspire brakes with 155r13/80 tires.
Tstat is a couple years old bought from Mazda.
Any ideals on what might be making it run cool?
Thanks David
History
90 fi 5spd
Rebuild head.
Thanks David
