Radiator upper mounting "posts" departed vehicle
  • Radiator upper mounting "posts" departed vehicle
    Both of the mounting/alignment posts on the top of my radiator separated from the radiator and departed the vehicle. The mounting brackets and rubber grommets are still there. Is it likely that a radiator shop would be able to weld some stubby pieces of rod in their place? It looks like the top of the radiator is a brass-like color. What material should they use? If so, I'd like to temporarily substitute another radiator from one of my lawn ornaments while this one is being repaired -- this radiator has only about 35K miles since new from when I overhauled the engine. Would I have to be choosy about which donor radiator I pick? The subject vehicle is an 88LX with AC. I have vague recollections about radiators from non-AC and AC cars somehow being different.
    I have a photo of the problem I can email if it's not clear what I'm talking about here.
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    the original radiators were plastic tanks and aluminum cored.
    the only differences were between the automatic and manual transmissions, the auto has a thicker core(most desirable)
    the aftermarket radiator is brass spray painted black
