i know most of you don't have 5drs, but i was just wondering if there's a bit of a common problem with the top edge of the doors rusting? i'm talking about the inside metal lip that holds the rubber door seal in place. as this is the 2nd Pride i've had and both seem to be doing the same thing.
and i jacked the car up today and the off-side rear wheel bearing was greased up but didn't seem to run that freely, and it wasn't the brakes rubbing. the other side not greased up very well but spun around very easily! any ideas on that one?
also i've seen someone on here (did a search but didn't find it) that has done a really good job of removing the air filter and replaced it with an upgraded cone filter. can some one please give me a quick guide how to do this?
this is my engine bay, and i think the filter must be in the alloy box that is in the bottom left corner. i haven't been able to take this a part as the bolts just run round.
thanks for any help given, pat.
