Low sitting in the front driver side
  • Low sitting in the front driver side
    My Fes sits lower in the front on the driver's side. the difference in space between the tyre and the fender is 1/2 to an inch less than on the passenger side. the shocks/struts were replaced with the KYB's in Oct. Saturday I'm going to swap the springs to see if that caused the situation (I swapped the springs when I did the shocks.struts), on Sat.
    anyone have an idea what might be causing this?
    "Nothing's gonna grieve us
    When we drive Festivas
    I could go a hundred miles an hour
    Long as I got the Almighty Power
    With my plastic Jesus
    Riding on the dashboard of my car"
    Are the springs set in the perches correctly?
      springs are in the perch correctly. pulled them apart, swapped the springs side to side, still sits low in the front DS corner. I'm going to order new rubber rings since they ones there look pretty well worn. And I discovered my left CV boot has a small rip, and there's a little more play than there should be (which may explain some of the torque steering troubles I've been having)
