Alternator belt trick: all from up top!
  • Alternator belt trick: all from up top!
    I was bummed today after leaving thoughts at Dean's funeral online guestbook. I figured what better way to follow that than to work on my car. And one of them always needs something!
    I had a new alternator belt to install and put Twinstiva up on the ramps. It's not difficult, but kind of a pain. I wish I had permanent ramps in my backyard. How nice would that be?
    On the other hand, I've often wondered if I could get to the lower alternator bolt (14mm, where it pivots off the engine block hole) from up top instead of having to get underneath. This would be especially nice for emergency repair/adjustment "on the road."
    I bet some of you more experienced mechanics do this anyway, but I didn't know if I could or not. I figured it was possible. So today I tried.
    First I used my usual long handled box end wrench. At around 11" or so, it was too long and the firewall and other parts limited any movement.
    Next I tried my large Craftsman socket wrench. Same thing, only it was even bulkier than the first tool and the socket added more space in the wrong way.
    So then I tried my Craftsman combination wrench. It measures almost exactly 7" long.
    First I felt for the pivot bolt head, which was easy to find, since I'm familiar with doing alternator and belt replacements. Then I fit the 7" wrench on and was able to undo the bolt till it was loose! SUCCESS!
    (Yes, I had already put her up on the ramps, but I didn't need to.)
    Belt got changed and I was able to just as easily tighten the pivot bolt. MISSION ACCOMPLISHED!
    I could've done it all from up top, with no ramps.
    From now on, I will. The new belt will undoubtedly need tightening in the next day or two and I won't be as lazy, knowing now how easy it will be.
    Now if the alternator needs replaced, it might be easier to do that from both top and bottom, but if you're not juggling a loose alternator, this will work fine, and using a short (7" long) wrench should prevent any chance of overtightening your pivot bolt.
    (Perhaps DJ and Dean were prodding me to be a bit more creative for a change, too.)
    Karl, feeling better
    cool thanks for sharing!
    1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
    1978 25th Anniversary edition Corvette
    1983 Chevy Elcamino
    1993 Ford Festiva GL
    2003 Hyundia Santa Fe ( Wifes Daily driver)
    some old dodge motorhome I have no idea of the year
      Thats how I took my alt. belt off was from the top, but I don't remember if I used a wrench or a ratchet.
      '90 LX
        I used to have a '91 that had a bad crankshaft seal, it would spew oil all over. Occasionally I'd have to pull the alternator and wash it out with brake cleaner. Got really good at pulling the belt off.
        Ahh, the memories of that car. The first car I bought from a dealer. Saw most of California in her. My friend and I would point to a spot on the map and just go there on the weekend.
        Sadly, being young and dumb I treated that poor car like a Ferarri and it didn't last six years. Biggest mistake I ever did was trade it in when the engine died. Shoulda kept it and replaced the motor. But now I have another one and will take proper care of it.
        John
        91L 5-speed, RIP
        89L 4-speed, teal/white
        http://johnriederer.blogspot.com
          DO you have an engine swap, or AC?
          My alternator is a piece of cake for doing from up top, no swap, no AC...
            Twinstiva is a stock B3 5 speed with no A/C or any other options under the hood. So there is as much room as one can get.
            I'm still tickled at being able to do this though.
            Karl
              I've also done it on B6 and B6t cars from the top... i think I may have done it from the bottom the first time but I'm not sure. I've done alternators all from the top as well, it just takes some wiggling.
              ~Nate
              Current cars:
              FOTY 2008 winner!
                Karl
                Cool! I was just wondering....
                  never had an issue changing the belt from the top....one car has air and one doesn't. Don't remember right now but I am pretty sure I had no reason to think I would have to do it from the bottom.
                  Glad you figured it out Karl
                    Ha ha. I think it's in the shop manual to do it that way.
                    I'm probably one of the last ones to figure this out!
                    Karl
                      Karl
                      Thats ok....you were just being CAUTIOUS and SAFE....lol
