So I've been having some weird running issues with my 92 Festy, and I'm beginning to think it's the throttle position sensor. I've been reading all over the forum ( yes I searched kthx
), and I read that if you disconnect the TPS and it doesn't change how the car idles, it may be bad. So I did that, and drove the car, and found it drives exactly the same. The ECU never threw a CEL either.
I took the TPS apart, and it appears to be just a switch for WOT and idle. Well, when I put it in the WOT or idle positions, and test the resistance across the appropriate pins, I get nothing. Not even a little tiny bit of connection shows up. Shouldn't I be getting SOME kind of continuity from the middle pin to either of the pins? I don't see how an electrical signal can pass, if my multimeter doesn't show any continuity.
Thanks!
), and I read that if you disconnect the TPS and it doesn't change how the car idles, it may be bad. So I did that, and drove the car, and found it drives exactly the same. The ECU never threw a CEL either.I took the TPS apart, and it appears to be just a switch for WOT and idle. Well, when I put it in the WOT or idle positions, and test the resistance across the appropriate pins, I get nothing. Not even a little tiny bit of connection shows up. Shouldn't I be getting SOME kind of continuity from the middle pin to either of the pins? I don't see how an electrical signal can pass, if my multimeter doesn't show any continuity.
Thanks!
