cv axle installation
  • cv axle installation
    got the old ones out now putting new ones in but im having trouble getting the ring to lock in place on the inner end of the axle that goes into the tranny, is th ring supposed to be positioned a certain way? like the part where it is seperated supposed to face upward? i noticed the ring can be spun around on the end of the axle, now I can get the axle end into the tranny to where it causes the other axle and hub to rotate with it but i know it needs to lock. any pointers for this?
    91 red l-
    did you pull both axles at the same time? if so, the geaqrs inside the trans can flip out of position. I believe you gotta pull the trans apart to fix
    Beauty is in the eye of the beer holder.
      man that is a bummer...
        Nahhhh....If he has resistance and when you turn one the other spins the opposite way....everything should be good. Is there any resistance at all when you try to pull them out? You can also try lining the axle up straight and tapping....(TAPPING means tapping) the end with a hammer till it seats. I have done it a couple times. It might just be easy to take apart.
        Have you tried putting you old axle back in just to see how it feels?
          Had trouble putting mine back in one time. For some reason if I put the gap in the ring pointing up it snaps in very easy. I have done it several times on different festivas and always seems to work this way very easy, at least for me.
          1960 willys pickup
          1967 jeep cj5
          1988 festiva
          1989 festiva
          1990 festiva for parts
          1991 s-10
            oh nah I knew not to pull both out at the same time, i did one at a time i figured it out I just had to /forcefully finess them in lol the new axles look way nicer than the oem, they are heavyier and thicker/stronger looking. now for that bp....
            91 red l-
              What brand of axles did you put in?
              1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
              1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
                Thanks for the advice on both axles, it's exactly what I would have done. I would have gotten the car put up and had my helper (aka son) pull one side while I did the other so as 'to get done faster'
                Now I'll know not to do that
                John
                91L 5-speed, RIP
                89L 4-speed, teal/white
                http://johnriederer.blogspot.com
                  not sure on the brand, have to check and get back on that
                  91 red l-
                    I have transported and stored transaxles without either axle in or even anything there and never had a gear drop. I have heard the same thing from alot of other people two.
                    The Festiva Store
