Front Grille Assembly
  • Front Grille Assembly
    I had 2 clips missing on my grille. I found some at the junk yard today. I tried to install them today but they didn't hold. Is there some kind of trick to installing these clips? I couldn't get them to work. These clips are really brittle, i broke a few trying to remove them after they didn't hold. Maybe there is something else I could use to try to attach the grille?
    Rich
    with the grille removed, push the clips into the grille itself where they are supposed to go, until they click, then stick the grille to the front of the car. be sure each one clicks in all the way. is your center grille clip intact (under the ford emblem) there should be a screw that holds the grille to the car there.
      Green Sales Company has new clips.
      Chuck
      91 GL -Ol' Rusty
      93 GL - Lil Red
      91 L - Tweetystiva
        The only clip that still intact is the one on the passengers side of the grille. I didn't know there was a screw holding the grille. Thanks for the info. I'll try to fix it tomorrow.
        Rich
          http://www.greensalescompany.com/
          Thanks for the link. I guess I'll have to call them and tell them what I'm looking for, since I don't know the part number.
          Rich
            you could always use zippy ties too lol
              Yeah, I was thinking that too.
              Rich
                PM sent
                Ian
                  There is another clip that works (same clip- but part list doesnt show interchange), I think from like a 96 or so Escort.
                  186,000 miles per second is not just a good idea, it's the law
                  1990 yellow L+ (l8ly)
                  1990 yellow L+ (sunryz)
                  1992 aqua L (agua)
                  1993 blue L (aurora)
                    Escort grill clip, part# BF67-50715(found the part bag). This is whats holding mine on now.
                    1992 aqua L (agua)
                      Rich
                      Do you realize that those clips have a release lever that must be pressed to get them to release?
                      I just took mine off today. I spayed them with WD-40, removed the one screw, gently pressed down on the release levers while pulling the grille away from the clips. If they don't respond to a gentle pull, the lever has not fully released them. Relax, take a deep breath, and try again. Patiently.
                      I Got them all off without breakage. When I put them back, I plan to first attach the clips to the body of the car. Then hold the grille up to fine tune their locations. Then press the grille gently into the clips until they all click into place.
                      John Gunn
                      Coronado, CA
                      John Gunn
                      Coronado, CA
                      Improving anything
