Horn parts missing, what should I do?
  • Horn parts missing, what should I do?
    When i bought my Festiva, the horn didn't work, and upon inspection, both the horn relay and horn are gone. I cant tell what wires are supposed to got to the relay, but i have found the wire for the horn under the hood. Can any one tell me what Wire in the steering column goes to the horn button so i can wire in a new relay, or give me some other advice for sorting through the wires under the dash?
    use a cirucuit tester like http://www.amazon.com/Equus-3410-Cir.../dp/B0014DINF6
      OK, here is the wiring for the horn circuit.
      Black wire from battery to main fusible link.
      White wire from main fusible link to stop fuse.
      Green/white wire from stop fuse to two terminals on horn relay.
      Green wire from horn relay to horn switches in steering wheel.
      Green/red wire from horn relay to horn.
      Stop fuse services both horn and brake lights, so if brake lights work fuse is OK.
      John Gunn
      Coronado, CA
      John Gunn
      Coronado, CA
      Improving anything
