Levistiva will not start with the key. Key in start position, lights on dash, but nothing. Won't turn over, doesn't click, nothing.
She is a 90 something 5 speed.
I cleaned battery posts, battery is charged. Checked both sides of fuseable links and I have power to both sides.
So, I turn the key to the "on" position and short a screwdriver between rthe starter posts, and it starts right up.
I'm kinda stumped. Bad ignition switch? Is there a neutral safety switch that can go bad. When I start the car, normally, I have to push in the clutch pedal for it turn over. Is that a neutral safety switch that requires you to push in clutch pedal to start?
Thanks in advance!
Thanks in advance!
