Weird lighting issue
  • Weird lighting issue
    Hey all,
    All my dash lights are working as are the rear lights, license plate lights etc. Funny thing is the front corner lights aren't I've changed out bulbs to no avail, they were old ones I had laying around so I am going to pick up new ones tomorrow. If that doesn't solve the problem does anyone have any suggestions as to what to look for?
    Thanks
    Ian
    my first one did that, corrosion got between light bulb and socket terminal.
    kinda like when gasket around front blinkers is bad..
    just had to clean inside socket, then they worked.
    might not be your problem, but, its a start
    93L sold. First FESTY!
    93GL Sold Too Soon!
      checking the connector behind the reservoir tank and behind the washer fluid can
        these bulbs are polarized .. you will not have a power meter like this?
        if I write badly....thanks google translator
          mine didn't work in uncle fester when i first got it. It was bc of corrosion. Took apart the connectors, cleaned, and they worked. Did you check for power?
          The new keeper of Uncle Fester!! 88 5-speed, efi, now with ac!
          1988 LX ~sold~
          1992 Blue GL auto, ac ~sold~
          2008 Nissan altima 3.5sl loaded <lease returned>
          1996 Nissan maxima <sold>
          2002 ford f350 crew cab short bed diesel
          Just remember, it could be worse, you could have a fork in your eye!!
            x3, I'd check for ground/corrrosion.
            Carz:
            '09 Ford F-150
            '80 Chrysler LeBaron Town and Country
            '80 Volvo 240 2dr coupe
            '93 Festiva GL
            225996.9 kilometers = 140428.0 miles on the odometer
            ...and definitely more soon..
              Stuck DRL relay maybe?
              White '89L auto - Sold!
              Silver '06 Rav4, 95k!
                I don't think that's it as the headlights do what they're supposed to! haven't had a chance to clean the connections yet so that's probably the cause. The odd thing is they were working, unplugged them to remove the corner lights, plugged them back in and they stopped working. I unplugged them at the big black plug.
                Anyways, thanks for all your suggstions. I'll update later after I get a chance to have another look at them.
                Cheers
                Ian
                  Got the park light issue sorted out. It was a combination loose bulbs and dirty connectors. Now I have another problem to sort out.
                  The driver's side headlight works just fine but the passenger side is really dim. My first guess was faulty bulb but that wasn't it so onto guess number two. Could it be a bad ground connection? I checked the EVTM and there are separate grounds for each side.
                  I'm going to try to improve the ground on that side tomorrow but I just wanted to get your input as well to see if there may be something else to look for.
                  I forgot to mention that these are the Mazda 121 headlights with H4 bulbs. I plan to get some updated photos of the car up in the next day or two.
                  Thanks again,
                  Ian
                    Headlight issue fixed... it was a bad ground.
                    Ian
                      Cool and thanks for posting what you had discovered was the problem. Perhaps others as they are trying to figure out their problem will see this.
                      - Unknown
                      - Quentin Crisp
                      - Bumper Sticker
