Valve Cover Baffle
  • Valve Cover Baffle
    Have serious blowby and removed valve cover to check for blockages
    Does the baffle plate in the top of cover attached with several small
    bolts suppose to have a gasket? Someone had siliconed baffle before
    attaching with bolts. Have seen mention of extra plate and bolt. Is
    this the small about 1" square baffle in front corner on driver side of
    cover? Any replacement pvc that would improve condition? THANKS
    for your input!
    I removed all the baffles on my BP valve cover and they did have silicone gaskets (stock). After cleaning everything really well I used FIPG I had laying around in the garage and it worked very well.
    Not sure about the B3 vc though.
    Oscar
      some valve cover gasket kits include the paper gasket for the plate
      no silicone needed at all
      only suggestion for the blow-by problem: new piston rings
      I am the original
        for your input!
        I took my plate off and cleaned under it. When I put the plate back on, I used a very thin bead of black silicone. That's what looked like was there. I see no reason that won't work in any case.
