wondering if anyone did a write up on installing aftermarket electric rad fans, searchd all week havent found anything, anyone able to use the stock fan wiring to do this or would i have to wire it to a 12v source , etc anyway if anyones got any info id appreciate it. thanks
electric fan installation
you adding a fan? or yours is bad? would be easier probably to find a used one so you have the shroud and all."FLTG4LIFE" @FINALLEVEL , "PBH"
You should be able to use all the factory wiring and just connect the wires to the new fan. Can't think of any issues. If you have an aftermarket adjustable sensor and relay, you may be able to wire them in the factory wiring harness. The aftermarket relay probably works opposite of the way the factory one does.Last edited by blkfordsedan; 04-25-2010, 04:31 PM.Brian
i mean i could honestly just not have a fan and be fine since im running and auto radiator but i guess i have the fan anyway so id like to get it wired up, i dont know about running it on a constant 12v source because i wouldnt want to put the unneccessary stress on my alternator, im trying to help not hurt
Claude I just ran mine from the stock plug. Just splice on some flat blade terminals in you can plug it in. Or since yours is bad cut the plug off of it and splice it onto the new fan. A BP needs a fan. Then it will function just like the stock fan.-Greg
Redneck Engineer
FOTY - '09
