Temp ,gauge
  • Temp ,gauge
    anybody can tell me why my temp gauge dont work ? 1988 festiva thanks
    your temp sender might be bad
      sender
      where is the sending unit on my 88 ? thanks
        you will see a single wire sender on the t-stat housing, that is the fan switch. Coming out of the wiring harness in the same location and to your left looking at the cylinder head near number 4 spark plug you will see another single wire sensor. That is the coolant temp sensor that operates the gauge. Hope that helps.
        91 Festiva GL "Scrat"
        82 Honda Goldwing GL1100i
        85 BMW 535is "Brunhild"
          sensor
          thanks i will look.
            years ago on my sunbird i was able to ground a sensor to keep the cooling fan running all of the time when the key was turned on and i wonder if i can do the same for the festiva?
              Why in the world would you want to keep the fan on all the time? Especially in a cold weather region? Put a switch in the cabin that you can control.
                just for the summer
                  I believe all you have to do is unhook the wire from the fan switch on the tstat housing and it will come on and stay on.
                  My Fleet:
                    Bingo!!!!!!!!!!!!!
                    we have a winner!
                    Provided the system is working correctly.
                    No reason to have he fan on continuously if your cooling system is running as it should.
