your compression should be from 90 to 120 for good compression harbor freight sell them for $18.00 the tester plugs right into your spark plug hole just need someone else to turn the key while turning over to get a read out
My New Car!!! Misfire problem Ideas?
^, no, compression should be no lower than 150psi (typicaly between 180 and 210)Trees aren't kind to me...
ok, will check injector, plug and wires first, then I will check compression if those are ok (since it will cost money)
1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
1997 Ford Aspire, MTX, Red, B3E - "Eggy" (RIP)
1989 Ford Festiva LX, ATX, Maroon, B3E - "TBK" (RIP)
1991 Ford Festiva GL, ATX, Red, B3E - "Festiva GT" (RIP)
Originally posted by pwgus View Postthe cylinder order is 1-2-3-4 from left to right, is that correct?Ian
