I replaced one with one from a j/y, then I bought one off of ebay, now today, my car died again, and I am leaning towards it being the problem again!
Ok, so my mom ran my car out of gas.. no problem.. filling it up is easy to do. It ran fine afterwards. Well, today I go to drive it and it seems like it is just cutting out while driving down the road. Cruising along about 45, shift to 4th and it bogs down and acts like it just shut off. After a couple hundred feet, it would pick up again and take off. Well, I thought maybe since she ran it so low on gas, it sucked junk up into the fuel filter. So, I went and replaced that for the 2nd time, and it fired right up and seemed like it was running good and smooth. So I leave the house, and after about 2 blocks it just dies on me. It will still turn over but won't start. My tach needle barely jumps when cranking which I believe means that it is not getting any signal to the coil to spark. Isn't that correct? Which leads me to point at the ign. module again. What could be causing these to keep failing on me? The first time it happened I had put an MSD coil on it and drove it for a couple months. I was told the MSD could have been too strong and burned the first one out. So, I put the old one back on, and since then it has burned through 2 more! What can cause these to burn up? Is there something else that it could be? Thanks for the help...
