Stalls in Neutral
  • Stalls in Neutral
    I have an 89 Festiva L - manual 4 sp. After replacing the clutch I noticed that the dash lights come on when I go into neutral while moving (coasting)- brake, shift, & check engine lights.. and car stalls. They go off when I put back in gear or as long as I rev engine high. ???
    88/89 idle problem
    I had exactly that problem after I let a shop touch my Anchorage '88. After several summers of living with it, I jumped a plane to Seattle to study the emission control plumbing on my '88 there, and determined they had messed up some of the plumbing. After I made it match the other car (more or less), it ran like a top. MOST of the plumbing has to be connected properly or the results are unpredictable. SOME of the plumbing can be connected in several different ways without bad results. If anybody ever comes up with a comprehensible diagram and word description of why/how it all works, I'm all ears! Recently, someone posted an '89 diagram somewhere on this site; I asked if they had an '88 equivalent, but never saw any response. Does anybody know if 88s and 89s are identical?
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
      88 and 89 manuals are virtually the same. The 89 auto went to EFI.
      I have the 88 vacuum diagram if you need it.
        88 plumbing manual
        Yes, I'd very much like anything I can get on the 88 plumbing. My daily drivers in both WA and AK are 88s, with only 37K since engine rebuild on the WA one, which is a zero-dent zero-rust LX with all the trimmings. I'll be driving these for a good many years to come. I've even been considering picking up another 88 with a blown engine and torn-up dash just for another example of maybe-correct plumbing. I'll cover any copying(color if needed)/mailing/whatever costs. PM me for my coordinates. Ralph.
        91L green
        91GL aqua pwrsteer
          Vacuum issue
          Yes - I have isolated to a vacuum issue. Thought I found the culprit and worked for a day - now back to the same. If you have a diagram - would love it - bballkevin@comcast.net. Thanks.
            Sorry all I have readily available is the 89 4 speed. Not the 88.
              88 and 89 are identical. I have both, but in b/w, not color. no difference between the two.
              Jim DeAngelis
