code reader
  • code reader
    Where does one find a scanner/reader to pull up trouble codes that works on a Festiva? I don't want anything fancy, just a basic model.
    take a look at this....no need for a reader
      Festiva has one "built in"!
        code reader
        Hi Pu241,
        Please explain how it works. thanks
          read this first:
          OBD1 cars have a built in trouble codes or check engine light in the ECU... thats it. No place to plug in a code reader, very simlple. And to do that from GenevaDirts link: Short the STI connector to ground and count the flashes of the 'Check Engine' lamp.
          John- you have better things to do.. didn't mean to steal your requested post
          -Aspire brake swap COMPLETE!
            Here is a good thread about it. http://www.fordfestiva.com/forums/sh...ad.php?t=17417
            Also weilley, where are you located, maybe someone nearby can give you some help if you need it.
            '90 LX
              ^thats a better read
                code reader
                Hi ejp2fast,
                Thank you for the info. I will give it a try. I have a well used Haynes manual. Are there any other Festiva's in this forum that have rust besides my 5? I'm from Northern Michigan, the rust belt.
                  code reader
                  Hi wybnrml,
                  Thanks, I'm from Northern Michigan.
                    Originally posted by weilley View Post
                    Hi ejp2fast,
                    Weilley-
                    Nobody else on this forum has any rust on their cars. I think your 5 are the only ones..
                    sorry- just had to say that. yes, typically northern cars of this age have little oxidation.... you aint alone on that.
                      Live in Southern Ohio, there is some rust to the frame under the drivers seat, lol.
                      88 L 4 speed Daily Driver with custom 2-65 AC
