Hi All,
I've got a 96 Aspire. The engine light code reads "misfire". It runs fine, maybe its a computer problem, but try explaining that to DMV in AZ. I was thinking maybe changing the plugs, and/or plug wires. I've had it reset a couple of times. Then, right before inspection I disconnected the Batt Neg for awhile. DMV said "did you install a new battery"? I cleared the fault, but there wasn't enough info on the computer....
