hey guys i rebuilt my b3 and put all new gaskets on. when i put it back together it will run but it bogs out on me over 2500 rpms and im no mech i just followed the haynes manuel and i need help :help:. whats more frustrating is it is still leaking oil right at th head gasket on the water pump side. i think i got the vac lines screwed up cause all lines are going somewhere but not sure if there right i need mi festy back......
boggin on me
boggin on me
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
Did you torque everything right?? Also I always use high tack for every gasket, even the head gasket :
