well for one, the engine needs a rebuild, i have an oil leak, and im burning oil. ill sit at mcdonalds and smoke out the person behind me. my rings are probably shot, valve stem seals probably are too. my brother in law has a cylinder honer but for as beat up as this engine is, honing might not do a good enough job. i dont know if ill lose mpgs or not, i dont even know if i will gain HP or not.
gas mileage dropped out
Originally posted by perucho View PostDid you check your timing?
I believe the timing is set at 700 rpm to +/- 1 degree with the white electrical connector or vacuum line disconnected and plugged depending on the year of your car.Last edited by kartracer46; 05-20-2010, 08:44 PM.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
Originally posted by MTec007 View Postwell for one, the engine needs a rebuild, i have an oil leak, and im burning oil. ill sit at mcdonalds and smoke out the person behind me. my rings are probably shot, valve stem seals probably are too. my brother in law has a cylinder honer but for as beat up as this engine is, honing might not do a good enough job. i dont know if ill lose mpgs or not, i dont even know if i will gain HP or not.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by MTec007 View Postnooo just gonna rebuild this one..if i get the time.. the car is driven 7 days a weeek90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
