cant figure out how the pins and the silver parts fits on the rotor....any help?
front brakes???
ok, there should be holes near the mushroomed end of each pin, the ends of the wire spring go in there, the hook in the center (facing up) goes into the center hole of the outside pad. the sheet metal pieces are your shims and should slip onto the caliper bracket above and below the inner pad.Trees aren't kind to me...
use a block of wood and a hammer...Trees aren't kind to me...
