trying to get the tranny off thwe b3 , all bolts are removed but it wont come off. it wiggles too. any quick help would be great thanks
got all the bolts out , traqnny wont come off.
Nope just pull all the bolts and she should slide right out unless somehow the input shaft rust welded to the clutch disk. Highly doubt that happened though. I didnt think I needed to pull all the little bolts out and mine would not budge. Pulled the last remaining little bolts and she slid right off. Good luck with it man.
Has caught the most Festivas on Fire on this board!!
The little bolts we're referring to are the two or three 10mm bolts holding the cover plate to the transmission on the oil pan side.Ian
ok i went over everything and theyre seems to be one little bolt inside the hole where the starter goes , it seems to be holding it to the block. i cant can my tools in there. ill figure it out though. cant wait to get this b8 in there. gunna be awesome.05 focus zx3 5spd 180k 2.5 inch mbrp exhaust , steeda sri and ford racing dynamic suspension
did you remove the 2 bolts holding the bracket/hose to where the starter was? that hose has to be moved.. i had the same thing happen to me, and i finally figured it out.. the last bolt on the right side of the bracket is a royal b for me to get off.
If you have removed all the bolts, you should have 4 tiny bolts, 2 medium size bolts, and 4 big bolts. The little bolt inside the starter hole does not have to be removed. Do you have a CV axle stub shaft with the cir clip on it stuck in the transmission? If you do that may be catching on the tin plate.You gonna race that thing?
get it back in yet?89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
bolts total...91L 5 sp, 175k,a/c ,KYB gr2,Fms Lowering springs ,13" konig's ,09 tiburon seats, 7" Pyle in.dash,kicker ds400 all around,Kicker 400.2 powering 2 Kicker cvr 10", 30k hid's, hopeful to find a xr2 to swap b6t from....
2010 mazdaspeed3 stock... for now
