Fan Blower
  • Fan Blower
    I have a 2-door 1991 Ford Festiva L. The blower is intermittent. Usually it will start blowing when I start the car first thing in the morning, and will work until I shut the car off, and will not start again. Then sometimes when I am driving it will start all by itself.
    I have checked the fuses, and the switch. Where should I look for the problem now?
    Please Help!
    tprice
    the blower motor is located above the gas pedal and to the right.
    held in by i believe (3) 8mm screws.
    if it stops blowing, next time rap on the motor with a small hammer or the like, to see might start blowing again.
      Mine is doing the same thing. It just started to do this. I will let you know if I come up with anything. I will let you know if I find any thing out.
      '89L 110k mi. BP/G swapped
      '90 F250 4X4 108K mi.
      '13 Kia Rio 5 LX 70k mi.
      '18 Kia Soul 40k mi. Daily
        Fan Blower
        Actually, I tapped on the motor just like they told me, and guess what? It came right on... So that works if you're having trouble as well.
        Good Luck!
        tprice
          Ive had the same problem on a few different cars like that. It has always ended up being a bad ground somewhere. on my 88 Blazer I had to take it all apart and re rivet the ground wire for the motor to the motor housing. I haven't taken a Festiva one apart yet but its something to think about
          Paul
          91GL
          Menomonee Falls, WI
            re
            mine was doing the same thing... i ended up replacing the brushes in the motor ... but unless u no what ur doin i wouldnt advise doing this on ur own
              yeah just replace the motor. save yourself some hassle. if ya gotta pull the dash (not sure) then i found a offest preke wrench that they sell at advance auto parts works great to pull out the top bolts by the windshield.
                why in the world did you have to pull the dash??????????????
                the blower motor is accessed from underneath, next to the gas pedal.
                  i dunno. never had to replace one. just said if ya have to. i know on alot of cars you have to pull the dash to replace the blower.
                    anything for a post, eh?
                    post mongrel!!!!!!!!!!!!
                      Arf arf arf!
                        sure, the post pooch chimes in :roll:
                          hey, i'm a post whore...not a mongrel
                            That's whoreable.
                            White '89L auto - Sold!
                            Silver '06 Rav4, 95k!
