Trying to get AC working again
  • Trying to get AC working again
    The AC has not been used at least since I bought the car(3 yrs in Sept) and has not had a belt on the compressor either. I put a belt on it yesterday and put some refrigerant in the low pressure side and did not get cold air. The compressor pulley sounded awful, pretty sure that bearing is toast. When I turned it off and pulled off the belt, the belt was so hot it burnt my hand. I did not hear the clutch engage or see the condenser fan come on, although if I understand the circuit diagram, the condenser fan will not kick if the clutch does not engage. On the plus side, the system did appear to hold pressure. The gauge that came with the refrigerant said it was full after about 4oz. So what should I do next here? Is it possible/cost effective to rebuild a compressor, should I buy a new one, is it likely there are problems other than a bad compressor? Any help would be appreciated, first time trying to fix AC.
    1993 Festiva GL
    new fuel pump
    97 B3 swapped in by Eurotiva
    Call me Steve.
    -Greg
    Redneck Engineer
    FOTY - '09
      Originally posted by eurotiva View Post
      Call me Steve.
      Why would we call you Steve
      As for the AC question it sounds like the compressor and/or clutch has seized up or is close to doing so.
      Ian
        I think that is syfir's name.:p
        91 Festiva GL "Scrat"
        82 Honda Goldwing GL1100i
        85 BMW 535is "Brunhild"
          I don't know Greg, everytime you look at my car, you find like 10 things wrong with it. lol. I'll give a call after work tonight. Thanks.
          1993 Festiva GL
          new fuel pump
            Cool I'll be here. Working on Casper
            -Greg
            Redneck Engineer
            FOTY - '09
