Last time I changed my oil I use Pennzoil Platinum full synth in 5W-30. I thought I would try it for the "superior cleaning power" they advertise.
it's been now 3K miles and It was a 1/2 Qt. low. When I look at the outside of the engine, there is at least 1/4 Qt. worth of oil film all over the top of the valve cover and seeping out of every intake hose connection and the oil fill cap. The valve cover gaskets look O.K.. I checked the PCV valve and it was good, but I replaced it anyway. I pulled the oil fill cap off while it was running and didn't see a lot of blow-by at idle, but when I rev it up it puffs light smoke like a Choo-Choo train!
The motor does have 140K miles, but it has had the oil changed religiously it's whole life. It was fine 3K miles ago and still runs perfect. No smoke @ start-up or while driving. I think it's a combination of the thinner full synth oil, the higher miles and the fact that the oil probably DID clean all the gunk out (be careful what you wish for!).
I plan on doing a compression test, changing the oil and cleaning the engine off. This time, I'll just use regular Motorcraft in 10W-30 and we'll see what happens. I'll do another compression test at the end of the summer. This may be a good excuse to swap a B6!
