Drove the car to work, ran as it always does. Got out in it to leave work and i have no ignition. It doesn't turn over, i have no dash lights and no stereo but the headlights work. It won't jump start, won't turn over, and won't push start. Any ideas?
broke down
Check the fusible links, check to make sure you don't have moisture there, or in the dizzy cap. Don't know what the weather has been like today in Cincy, but it's been raining cats and dogs here. Any chink in the Festiva's armor, and moisture will find its way in.
1989 L - 247K miles Slick
Originally posted by batstiva View PostCheck the fusible links, check to make sure you don't have moisture there, or in the dizzy cap. Don't know what the weather has been like today in Cincy, but it's been raining cats and dogs here. Any chink in the Festiva's armor, and moisture will find its way in.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
Originally posted by wybnrml View PostI'm not sure if it's the fusible link, because if it was, the headlights wouldn't work.
Ah, he might have to check the battery post connection and the battery connection at the starter and see if they are loose or corroded.91 Festiva GL "Scrat"
Middle fusible link is dead....replace it and all should be well.
IMO....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Look on the front of the left or driverside shock tower. You will see a brown box with what look like three wires looped in the top of it. The middle wire is most likely your culprit. jump the two prongs together with a piece of wire and have someone try to start the car. If that works let me know and I will send you a picture and description of the replacement fuse that will fit in its place or text me at 757.705.3592 and I will text you some pictures back.Last edited by kartracer46; 06-06-2010, 08:24 PM.91 Festiva GL "Scrat"
Wow you guys know your stuff. I got out of work this morning and this is my "Friday" so i've been expected my weekend to totally suck and be out in the sun baking trying to fix this turd...but you guys nailed it on the head. I jumped a wire between the two prongs on the middle link and it fired right up. Now all i need is pics/info on what fuse to get to replace the wire and she'll be back on the road just in time to not screw up my days off.
:notworthy:
Actually....there are a couple Festivas locally in the junkyards...would it be better to pull the rope fuse off one of those or am i just asking for this to happen again?Last edited by Evil D; 06-07-2010, 06:01 AM.
Should have those "fuses" to replace the "fusible links" at any good part store.Dan
