Well, this is the FIRST real problem I've ever had in 147K miles of driving.. This is my '93L, B3 EFI, 5SP, no A/C.
I noticed the engine would occasionally die when idling and the idle was a little erratic, but only once in a while. It was that way for several months until yesterday. Now, every time I stop and take my foot off the gas it just dies. In addition, if you try to apply more than 3/4 throttle during acceleration the motor misfires and blows a cloud of light blue smoke out the exhaust. I'm thinking it was loading up on gas, but the smoke is not the typical black associated with over-rich condition. My first thought was a bad TPS or coolant temp sensor. I installed a used TPS off my parts car (which ran fine when I parted it out) and the problems were fixed...OR SO I THOUGHT!
Later today it started acting up again. The idle drops and the engine dies as soon as you let off the gas. However, the 3/4 throttle issues appear to still be fixed. Also, I just noticed that the idle issue ONLY happens when the headlights or fan blower (heater) are running. If no accessories or lights are on, it idles perfectly smooth at 750RPM. I have 2 guesses that I'm thinking of:
1) I need to adjust the new TPS sensor (but I can't find my Haynes manual for the specs)
2) The IAC is suffering from a lack of voltage when I turn on the lights or blower motor. That means I have a bad connection or electrical issues with the battery or alternator or something.
If anyone has any other ideas or experiences, please share!
