ya i feel the same way , thats why i'm posting all results hoping it will help someone else ,
latest update is i replaced gasket on bottom of in-take plate and top of in-take plate " the plate that heats the gas before going into the in-take manifold" didnt seem to fix issue
out of frustration i started turning the only a/f mixer screw on the whole carb and as i turned it in it got worse and so i turned it out and the car leaned out and ran super smooth, my guess is the old man that owned it before me messed with it, not understanding everything is ran by sensors and switches, i was scarred to mess with it because it so hard to get to and keep track of your turns no room for a screw driver had to use a ratchet with a phillips head
then i drove around all day yesterday and when i take off it now has a stall , ya know like a dead zone at beginning of throttle , anyone have any ideas what causes that everything else it seams to run perfect
i unhooked the battery all night to clear codes , drove it this morning as soon as i started it up, the check engine light came on ---- code 70- vacuum switch ---- how do i know what switch it is ? ,, or is it possible that all night without stepping on the brake peddle isnt enough to clear codes will try again to make sure cause the light came on as soon as i started the car witch is either old code or something is unplugged or just faulty?
just found out all cars in my county have to pass emissions starting june 2010 ,
that really stinks!
that really stinks!
:yay!!!
