Just purchased a 90 Festy 5 speed. Love it. While driving the other day, the thermostat bypass hose leaked down most of the coolant before I smelled the trouble. After replacing the hose and reloading the system...now when I crank her up, there's so much pressure in the cooling system that it will literally blow the overflow hose off and shoot coolant about 6 feet. Would it be safe to assume the head gasket is cracked between a combustion chamber and a water tunnel ?
Thanks,
Tex
Thanks,
Tex
