I plan on converting my BPD Kia Pride to Automatic tranny.
I need to know all the parts needed for the conversion
This is what I know so far:
=Auto TRANNY
=STARTER
=PEDALS(Brake and Accelerator)
=SHIFTER CABLE
=SHIFTER with CONSOLE BOX
=CROSSMEMBER
=AXLES (L & R)
………..I might be missing some small details
-Does the Manual and Auto tranny have the same Spline count on the axles(end of axle going to tranny)
-Do they have the same axle length (L & R)
-How can I let the Automatic tranny shift in 6.900RPM
-Can the Auto tranny hold the power of the BPD
-How do you properly launch Auto tranny in Drag races
-What are the pros and cons of this Auto Conversion?
Thanks in advance
=Auto TRANNY
=STARTER
=SHIFTER CABLE
=CROSSMEMBER
=AXLES (L & R)
Thanks in advance
...Carbon Kevlar Hood and Roof
which now impaired the proper function of my left leg......and for me to still enjoy my Kia Pride is to convert it to Automatic......problem is....its only 3-speed auto......my car will now be slower, right?
) cross member from auto but i think manual is the same. flywheel, kick down switch, tranny support front and rear, it is not very difficult to do this swap but it is a little bit harder to convert the small tranny to handle 140-150 hp or more but if you have a good machine shop around you ( 4 parts to cut ) you can do it with not too much troubles.
