My car('91 on stock ignition, harness, and ecu) is throwing a code 01. Check distributor wiring to IDM. I have a spare ignition module that I thought was good, threw it on, same thing. I don't have an easy way to get another IDM, and any new replacement is at least a week out. Is there any way I can test the modules I have to see if they work?
From what I understand, when the IDM gets a signal from the ecu(pin1) it connects ground(pin2) and coil(pin3). Is that signal + or -, or is it some kind of wave? Does it function like a relay where it stays grounded as long as the signal is present, or does it only instant connect to trip the coil?
Would installing a MSD ignition system bypass this problem and what's the easiest tach signal to use with it?
