I have a large hole in the A/C condenser on my '97 F250. It has been out of Freon (R134) and open to the air for about 3 years. The compressor was unplugged within days after the condenser was punctured, just to keep it from turning on with the defroster and running without any lube. Before it happened, the A/C would freeze you out of the cab.
I don't know much at all about A/C systems, but I'm thinking about buying a good used condenser ($50 @ local junk yard). I've also heard that you should always install a new accumulator/dryer on R134A systems. They run about $40 on ebay.
If I install a good used condenser, new dryer and new o-rings, shouldn't I be able to take it somewhere to have it sucked down, tested & recharged?
Would the compressor go bad, even though it's been unplugged? Would the other o-rings in the system dry out? Is there anything else I should look at or do?
