My festi has the original dealer installed AC. Hasn't worked since I've owned it. Found out why. The high pressure line fitting going to the drier/accumulator is bad. The accumulator itself doesn't look that good. Compressor turns ok. I may be able to find a replacement drier/accumulator, but wondered if anyone knew where I might find a replacement high pressure line that goes from the accumulator to the firewall. Or, is a retro-fit piece for that line possible.
Thanks.
Thanks.
