Car: '90 Festiva l-plus, 5-sp. Previous failure: alternator, lead to dead battery.
When I start the engine (Foot on the Brake) the alternator belts squeals alittle at idle [900rpm] until about a minute, the idle smooths out & squealing is gone. If I step on the brake pedal, my RPMs drop 200 and the belt start squealing, again. Squealing will get worse the higher the RPMs [Stinks too!].
I have a new Alternator and Belt. I tried Belt dressing spray. I feel I have the Belt tension too tight , I can barely get any deflection. In the Haynes manual, it says I should have: one volt on the "L" terminal with the ignition on. I get almost 4 volts. Is this ok? It does not say. All other tests are ok. I do not know if I am getting 35amps out of it, If I need it. Voltages ok. I checked my Water Pump, it spins easily. The belt dust is on the Alternator body, so it must be slipping there. Battery staying charged up. Thanks for any suggestions you can give.
