My mother inlaws 89 efi festiva wont start. They changed the fuel pump the coil, cap and rotor, wires and plugs. It cranks good im not familiar with these little cars so any direction would help.pulled the plugs and there is spark. The problem happens when she drives down the road it will stall and then she can put it in neutral and restart it until this last time it died for good. This last time was a couple weeks after the fuel pump and plugs were changed. I smell fuel when its being cranked and i wide open throttle it. Any help would be great.
Weak spark and no start
Was all the stuff that was changed done to address this problem, or is this new since after the work was done?
1989 L - 247K miles Slick
Ok from what i was told she had this problem for awhile so they changed the plugs. It was fine for awhile. It happened again and it died completely so they changed the fuel pump and coil. I just did the cap and rotor and wires tonight cause the spark was weak it now has very good spark. I pulled off a fuel line and cranked it and plenty of fuel came out so fuel is getting to the injectors. Is there Anything that would make them not fire or does that go straight to the ECM?? I also check the timing belt that looked in good condition and was not slipping when cranked. So any thing you guys know i should check let me know. I dont have my compression gauge here so i cant chk those. Thats what i want to chk next. I removed the intake tube and sprayed it while cranking with starting fluid and i didnt get anything. Any input or ideas let me know thanksLast edited by bikerman5345; 07-22-2010, 08:17 PM.
I read a post where there was a problem on a Festiva similar to yours and the Injectors were not working. Believe it was electrical. Fuse?
Use the search function, and you should find it. I just got on site to do a search for some problems myself, or I would look for it for you. Good luck.Last edited by drddan; 07-22-2010, 08:46 PM.Dan
I had a similar problem on an '85 S10 blazer. It had all the makings of a running engine, but wouldn't start. Spark, compression, timing, fuel. Still no joy.
I finally bought a spark testing tool. KD tool 2756. It looks like a sparkplug with an alligator clip soldered onto it. No spark with the tester. Changed coil and that solved it.
I know it was posted that the coil was changed. Along with the rotor, cap wires and plugs.
I just think that for the sake of not chasing suspected issues I would want to verify that the ignition is strong enough to get the tester to spark.
Being you posted that you tried starting fluid and still no start I would still suspect an ignition issue.
Just my 2¢.
Intermittent stalling is a sysmptom of a failing ignition control module, ie transitorized points. You can take the module out and have it tested for free at some auto parts stores. For more info look in www.ag384bn.bravehost.com/Cars.htmOriginal owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Main relay, driver side inner fender, on a bracket next to the radiator overflow tank, just behind the headlight. Small metal can with a pigtail wire connection. replace it.Jim DeAngelis
If it's getting fuel and spark, I'd think it would have to be a timing issue or compression. Whenever I change the rotor bug it messes me up, why did they make it fit on three different ways Last edited by Occhty; 10-12-2010, 08:47 PM.
Mark where it is pointing before you change itOriginally posted by Occhty View PostIf it's getting fuel and spark, I'd think it would have to be a timing issue or compression. Whenever I change the rotor bug it messes me up, why did they make it fit on three different ways
Diagnose, THEN replace!
I would line up the timing. Make sure everything is pointing at top dead center, and that the rotor is pointing at the number one cylinder. You checked for good spark, nice and blue? Were the new wires the cheapo depot kind? I have bought some where the plug seems to slip off the coil...
Check for water in the oil, and oil in the water. That compression test would be a GREAT idea. Autozone loans them out....Contact me for information about Festiva Madness!
