is there a way other than removing brake rotor,
cv boot need replacing 92 festiva gl
Do not need to remove brake rotor to replace CV boot or the whole axle for that matter.
Not certain you have asked the question you really wanted.
You can used a split boot to replace a torn/lost/destroyed boot.
But this is not a satisfactory repair.
Your best bet is an axle replacement.
It is more expensive, but a more permanent solution.'93 Blue 5spd 230K(down for clutch and overall maintanence)
there isn't anything that you'd call a "back plate" on the front hub.
Maybe you are referring to the rotor shroud?
In any case a using a kit, called a split boot, you can replace the failed one without removing anything other than the old boot itself.
If you use a single piece boot, the axle nut must come off as well as the outer tie rods. so that the axle can be removed from the hub and the new boot slide over the now exposed axle.'93 Blue 5spd 230K(down for clutch and overall maintanence)
