i dont know wat goes here???? and i dont know where the black bracket goes??? im so flustered plaz and thx pics in 10 mins.
need help bad plz!!!
Originally posted by dragonslit View Postjust hole???
other pick is kinda blurry93L sold. First FESTY!
91L blue monster "BP swapped!" Robbed of its Heart for other Festy!
91GL blue bandit(thanks to sparky) Sold twice! lol
89L (thanks again to sparky) "SCRAPPED without my permission!!!!:nono:
93L Clean Green Machine! (Thanks to Sedat)-Sold to other member!
89 Auto LX Wrecked and stripped. violin
93GL Sold Too Soon!
91GL BP powered, ALL OPTIONS! banana time
Sorry, but I cant make out that pic either.sigpic
Are you working on the tranny ?sigpic
The only brackets I can think of on the tranny are the clutch cable bracket, the starter bracket and there is a bracket for a down pipe support. Im headed your way for some mini golf. We will talk about it then.sigpic
It looks like the bracket that helps support the engine to transmission. The one you have pictured looks like it goes on the side of your engine toward the firewall. Look at where the oil pan attaches to the block at the transmission end of your engine. There should be 2 holes there in the block just above the oil pan. If you match the holes up with the bracket, you should see a hole in the transmission (bell housing) that will match up with the single hole in the bracket. There should be one of these brackets on each side of the engine in the same location.You gonna race that thing?
Unless you are using a transmission other than a Festiva/Aspire, it has to fit. If you have it in the correct position, it should cover the area where the oil pan contacts the block and the 90 degree bend at the end of the plate with one hole should match up to the threaded hole in the transmission. The overall length of the part is 6". If your length is a lot different, your part may be something different than what it looks like it is.You gonna race that thing?
it was off a little bit but it was the engine to trans mount faceing firewall i had to readjust the engine. had problems with the bolts comeing out forgot about that. new issue is transmissions gears are off. like where 3rd and 4th Should be is where 1st and 2nd ARE. where 5th and reverse SHOULD be is where 3rd and 4th ARE.. apparently shift gate soo...
can someone run me thru replaceing my shift gate in old trans or can someone do it if i send it to u pay u and pay for it to be sent back. deadlines aug 13th for completion date. plz and thx pm me if needed.
It's always a good idea to take clear pics, show the area from a decent distance and give clear and precise information to what you're working on and doing....
B/c if the experts on here say ????, then your post is not clear.www.cardomain.com/id/jermnc77
Madness Committee Member & Contact Person
www.festivamadness.com
Festiva Madness
Snoopy's
4621 Atlantic Ave
Raleigh, NC 27604
