So let me give you the run down of how my stiva went from perfect(well good enough for normal driving) to the way it is now.
1) It is dead one morning when i need to go to work, jump it and i drive it for awhile(2-3 weeks) and it needed a jump once or twice.
2) Put a new battery in it driven for a week
3) Then it overheats, i get it home look it over. No belt to alternator and waterpump. Put a belt on, it overheats.
4) Ordered a new thermostat(motorcraft) in and then a thermostat housing(cracked the first one). And put new hose clamps on upper hose. Fill it up with coolant. Jump it because the battery was dead (.83volts) Start running it to check for leaks and get shocked. It was arcing from the distrubutor cap to the hose clamp on the upper hose. This was friday (7-30-10)
5) Today i put new plugs, wires, rotor, and cap on. Jump it cause it was dead (1 volt) again. And run it and it gets at about 90% on the heat guage after driving around a little bit. A friend recommended i check the amps on the battery, then pull fuses till one makes the amperage drop at the battery. Well my cheap meter goes up to 10A and i put it on there and it went over 10A and started heating up my leads on the voltmeter(once again its cheap).
I need help to get this to stop overheating, hold a charge, and I am running out of ideas. Is there anyway to know if I need to do the waterpump and what should I check for with that large of an amp draw?
Thanks, I really need to get this fixed tomorrow as I have driven the wifes car for 3 weeks now.
