OKAY, i just replaced the water pump on my car and i thought the belt looked good, (and the 2 screws that held the harmonic balancer inner ring had stripped heads, so i couldnt change it) so i just did the water pump. fired up beautifully and i waited for it to circulate the cooling system to check for leaks, i rev it up to 3500 a few times and let it go. exactly when the cooling system kicks on the car dies. i instantly check everything i can think of. i crank it once, and by that sound, i knew the timing belt broke. i checked it and confirmed. what are the chances that nothing happened to the motor? slim to none right? %$#$! i cant even put another belt on for sh..s and grins, because i cant remove those 2 screws to remove the harmonic balancer. it doesnt matter, the b3 isnt non interference any way..
Timing belt... Dun Dun Dun....
Umm the B3 IS non-interference, throw a new timing belt on and you should be good to goOriginally posted by MTec007 View Postthe b3 isnt non interference any way..
Doesn't matter what year it is, they are all non-interferenceOriginally posted by MTec007 View Postreally? i thought it was not? were talking the 88 B3 right? not the FI or aspire B3
EDIT: wybnrml beat me to it this time :lol:
Mabye you could use an easy out tool to get the stripped bolts out!Originally posted by MTec007 View PostOKAY, i just replaced the water pump on my car and i thought the belt looked good, (and the 2 screws that held the harmonic balancer inner ring had stripped heads, so i couldnt change it) so i just did the water pump. fired up beautifully and i waited for it to circulate the cooling system to check for leaks, i rev it up to 3500 a few times and let it go. exactly when the cooling system kicks on the car dies. i instantly check everything i can think of. i crank it once, and by that sound, i knew the timing belt broke. i checked it and confirmed. what are the chances that nothing happened to the motor? slim to none right? %$#$! i cant even put another belt on for sh..s and grins, because i cant remove those 2 screws to remove the harmonic balancer. it doesnt matter, the b3 isnt non interference any way..
Here's your answer. Took like 5 seconds to find.Originally posted by MTec007 View Postare they not in the way of removing the harmonic balancer? so they are there for a reason..
