Hey guys well this not exactly an aspire or festiva but its the same time period
. I tried posting on other forum boards but all those guys suck with answering questions, and you guys seem to know a whole lot more than they do!..Heres the deal, I just bought a 92 honda civic hatchback the guys whom I bought it from had his friend put in a new clutch, well after he did the car would go into gear but will not move at all? I pulled the engine and took the tranny off and the clutch was put in correctly. The pilot and throw out bearings were bad tho, he didnt replace them. I then put the tranny back on and decide to gv the crank shaft a turn, so I did and were the axles meet the tranny was moving fine, even in every gear. I did notice it was very easy to remove the axles when I was first taking them off, they popped off with a flat top screw driver with little force. So I still have the engine and tranny pulled and I'm not sure what is wrong? You guys have any idea what could cause that?
