i have an oil leak coming out of the front of my engine. i think it is the front main seal. i was wondering if this kit is what i would use to fix it? also is this a very complicated or time consuming job? thanks http://www.partsamerica.com/ProductD...pe=925&ptset=A
front main seal
That will work, all your getting is just the seal not actually what is pictured there.
Check your crank for any wear. Here is a thread on a recent problem:
If you can do a timing belt replacement then you can do this.
