So I'm still chasing the actual problem that is plaguing my car...here's a recap of everything to date:
Problem: #4 cylinder compression showing 30 pounds dry, 0 pounds wet (all other cylinders 150+). Runs horrible when attempting cold start @ night, but during the day it's not nearly as bad. Very light gray-colored smoke coming out the exhaust. Mechanics want to pull the head and replace it entirely...I would rather suspect the head is fine and it is a valve issue instead. Only getting 26MPG. All cylinders getting strong spark, #4 wire can be pulled out with no change in engine performance. No fuel delivery issues. No coolant issues, oil changed 1k miles ago and isn't burning or leaking...slight traces of blow-by, no vacuum issues, PCV system working properly. Runs like crap at idle in drive or reverse, runs smooth at highway (60+ mph) speeds or higher RPM.
Things done to date: Two sets of spark plugs (First was Bosch +4's, then swapped to NGK V-Power's...made it run a little better), new wires, new distributor cap & rotor, new PCV valve, Cylinder Restore & Seafoam ran through oil, Seafoam and Marvel Mystery Oil ran through fuel system. Just changed the engine coolant temperature sensor (the one under the intake, not the ones by the thermostat housing). Oil change recently, using 10W-30 Valvoline high mileage & Fram filter. New air filter as well.
I believe that is everything...anyway, with all that being said, is there a way to better pinpoint what is going on without thinking I have to replace the entire head? Thanks to all who have helped before and who can offer some fresh insight on this problem.
Will
Edit: oh, and I know this might sound odd...but the exhaust coming out of the tailpipe kind of smells like pepperoni, lol.
Will
