MY festy is spurting off coolant from the reservoir vent tube, the coolant should be catched by the reservoir but it doesnt go down the reserve tank, and just spill straight out of the vent tube,, Iam not overheating, the needle of temp. stays in the middle when Iam moving and slightly goes higher in the middle when Iam on idle or waiting at a stop sign, I also dont have white smoke on my tail pipe,
I recently flushed the radiator about 2 months ago,, I also bought a new radiator cap,, should i just plug that vent tube from the reservoir to avoid spilling coolant? also I discovered rust of the underlying metal parts from where the spill takes place, I assume for years the coolant kept on spilling and the previous owner did not treat the issue developing corrosion form the spill.
Any idea how to treat the coolant spill properly?
