I've worked on 3 different cars (1 festiva, 2 aspires) removing cv axles and each car had a different problem and solution for the removal. Two of the above mentioned cars had bad axles tha needed to be replaced. So it didn't matter how we get them out as long as they moved.
So for the more seasoned mechanics out there... what's the tip on removing a cv axle?!?
I'm looking online and searching local shops for a "CV axle removal tool" and have only found one tool that looks "promising".
Does anyone know the diameter in mm of a cv axle? The tools I found on ebay are for 63mm or 48mm.
