The car is a 91 b6d 5 speed. Getting very poor mileage. Went thru a tank over the past 2 days. 8 gallons got me right at 140 miles. I bought the car not too long ago wanting a car to drive as a DD that got better mileage than my other cars. As of right now it gets the worst mileage of all 4 of my cars. When i bought it i averaged 20mpg on the highway.
What it does - when first started in the morning it will not idle. If i start it and dont give it gas it will die. It will continue to do this for the first couple minutes of driving. Once warmed up it will idle nice and smooth. Once warmed up, if i turn it off and then restart it, it will die again. I have to give it gas for a few seconds and then it will idle smooth again. While driving, if i am accelerating, it runs very smooth and pulls strong. If i am just trying to maintain speed it will start to jerk a little. When it starts to jerk i either have to downshift or accelerate to get it to smooth out. It does not have a smell of gas so i dont think it is leaking. The tailpipe is coated in black soot. After sitting at a traffic light, while accelerating thru 1st and 2nd i can see a cloud of something behind the car coming from the exhaust. At WOT i can see the same cloud behind me. As soon as i let off the throttle it will go away.
What has been done - the car came with a fairly new exhaust system from the PO. I have replaced the o2 sensor, plugs, wires, dist. cap, and rotor button. When i pulled the plugs, all were pretty black and one was completely fouled and covered in gunk. Cleaned the MAF. Checked the injectors to make sure they were firing properly and run Seafoam thru it with the last 2 fill ups.
I have not checked for vaccum leaks yet. Will be doing that with carb cleaner today.
What else do i need to check? I was expecting double the mpg when i bought this thing.
